Cone filter instead of box
hamer
What all do i need to install a cone filter on the MAF housing. Does fram or anyone else make the filter. I seen a 84 Gn with the hookup and it looks alot better than the air box. Theres a parts store going out of business and got 40-50% off everything gonna try and stock up on plugs, fuel filters and stuff and was hoping to find the cone filter and get that airbox out too.
I work at a parts house, and the only cone filter that i could find for my car was the K&N. I don't remember the part number (just look it up by diameter) but connect the K&N to the 90 degree elbo that usually goes to the box and loose the box. If you want to make a cold air induction (outside the engine compartment) extend the intake after the filter with some alumnum tubing ealy found at a hardware store. I used some AL housing for a dryer from Home Depot it cost something like $9.00 once you get the correct filter you will figure it out.
