Wiring up the Camaro (Soon) with the t-type drivetrain and I'm confused about the high/low fan. I won't be running a/c. And I doubt I will run the Delay relay. Now let me see If I have it straight, the ecm controls the low speed (chip change can control the low speed turn on point too right?) and the coolant fan temp switch (in the manifold under tb) controls the high speed fan.
Now, I'm not too sure that I'll be using the T-types fan motor and will probably be using the Camaros electric fan (Only two connectors) Any ideas on how to wire this? I would really prefer to have the fan come on like it should rather than use a toggle switch because my wife might drive the car sometime.
BTW, why was there a high/low speed? Seems like a single speed would have been fine.
TIA
TIA
