Blown&Injected
- May 31, 2001
Springs and Shocks too; I need to do it all and have read so much about so many different options that I fear that I have learned just enough to be dangerous.
General Goals: I would like the biggest brakes that will fit in the current 15" Centerline wheels, I would like to keep the wheels in the same place as stock, and maintain about the same ride height. Have also read and been told about bump steer when mixing up parts to make it all work - certainly do not want to make things worse.
Many set-ups I have read about are arranged around certain available parts, however, if you had to do it all with 15" C/L Convo Pros, 215 65's up front (this can change a bit if it makes a difference) and 255 60's out back, but will probably going to 275 60 Drag Radials, how would you do it?
Thanks.
What I had in mind was to use G-Body Parts upper and lower control arms, Moog springs, and it sounds like I can modify the stock spindles to accept better calipers - but can I use bigger rotors by doing this?
I'm doing some parts research right now - So how does my plan sound?
Thanks.
