converter lock up problems
JeffRender
I had my WE4 out for a highway cruise last weekend and I noticed that I was turning around 2600-2800 rpm at 65 mph.
I posted a message and I was instructed to do the brake peddle test and it works fine at around 45mph I see the rpm go up slightly when I hit the brake and go back down a second after I release,but when I take it up to around 65-70 the converter is unlocked. I have performed the same test at higher speeds and I see no change.
Any suggestions
Jeff
My guess is bad 4th pressure switch or vss something is out of whack in that line.:D
check fuse in fuse box on the right close to top says ecm sol its a 10 amp fuse.
I just fixed one on a car with shorted solenoid kept blowing fuse...replaced solenoid and works great now
