converter question
turboaddict2
do torque converters limit how much boost you can run no matter what your combo is? I still have a stock D5 with a pt51(laggy with the D5:( :mad: ). I wonder if the stock D5 limits boost.
For what it's worth...
Originally posted by WE4
The correct stall for your car is the one that works the best " In your car".. I would start at 3000 but my 3K is I'm sure different than yours. What you are looking for is effecientcy and yet stall the PT51.Most of the combos simliar to yours works well with a 9X11 at a rolling 3000 stall. Ask the guys who are using it . Ask for guys with pt51 and your injector size. You may try 2 or 3 converter combos till you find exactly what it is you are looking for. My suggestion is work with a vendor who will work with you. You can try several combos in the same converter to see what it is you like, or the car, likes best.
Bruce
WE4
www.ptsnctb.com
