I wrecked my '86 GN but I a have an '84 lined up. My drive train is fine, are there any unseen complications that I should know about? I plan on swapping the motor, trans, and rear.
if it comes with the hydroboost master cylinder,you ll probably want to convert ity over to the vacuum system-it s hard to make it work with the 86/87 powersteering pump and pulleys-i tried.
yes-you will also need the pedal-the pivot point is in a different location,i just completed a 84 to 87 conversion so let me know if you have any questions.matt
