Converting a hd actuator to a standard
Sal Lubrano
Is there a way to lower the boost pressure with a hd actuator? I would like to go back down to 15psi and I heard there is a way to do this with an extra spring.
You take a spring and put it over the actuator rod then slide a washer and nut on. Adjust the nut until you get the desired pressure. The spring counters the spring in the actuator. I did it on one of my cars and it works great. I got the spring at ACE Hardware. I had a picture of it somewhere just can't find it at the moment. :smile:
found it
mikestertwo
