Converting to V8 Rad, finally through with the small V6
BuickTV6
kicking butt Intercooled
Hey guys! I see a lot of you have converted to either 86/7 GN rads or to a V8 rad. I got a great deal on a brand new V8 rad, and before I install it I have a few questions. First off, can i use the same hoses i used with the smaller V6 rad, or will i have to switch them to 86/7 hoses cause the rad is bigger. Also, will the 86/7 upper rad piece from the intercooled GN's just bolt on to the top of the rad? or will it require any modifications. I'd like to run the upper rad piece and the cooling fan off the gn, so it will look like it came from the factory. I am in the midst oh having new intercooling piping made up mandrel bent and powder coated to replace the ones that came in the turbomotion kit. I will post pics when its done. Thanks in advance Tr guru's!
i used the original hoses when i switched mine when it was hotair
the top plate will bolt right up to the top of rad support it alread has the holes
just move the rubber gromets in the lower support out to line up with the v8 tanks.
you could do like i did and just use any v8 cutlass or regal top plate and use after market fan(s)
