I took the GN to Raceway Park for its first trip down the 1/4 ....The motor only has a few hundred miles on it...So I figured I wouldnt go crazy with the boost...My first 2 passes the car ran 106mph...19 psi On pump gas...
I figured the car should be running better.....So while in the pits before the 3rd run,I uncapped the exhaust(Single Shot)...I didnt lock the T/C on either of the first 2 passes...So I figured I would lock it off the line this time...
This pass the car jumped to 115 mph...nothing else changed...Just open the dump,Lock the T/C..Now...That seems like alot of mph to gain...My boost held steady @19lbs. So I wouldnt think the exhaust had much to do with it...The converter is pretty new though...with barely any use on it...Its a Pro-Torque 3200.
How much slippage should I expect from a non-Locked converter???I
Is there a horsepower level that you should start looking into a Multi-Disc T/C??
19lbs and no timing(Pump Gas) The car put 432 to the Rear wheels...
Guess I will have to send it out to be checked out...
