coolant ?s
wicked6
How many of you in Florida just use distilled water and no anti-freeze. Also, How many use water wetter?
Thanx
Most use just distilled with some sort of pump lube. I've heard that redline water wetter will gum up a radiator in no time. Stay away. Use RMI 25 instead.
I can verify that about "Water Wetter"...how about having to replace a radiator in a PS Diesel after using it!!
Using RMI-25 & Evans Coolant now---doing great!
HTH :)
I guess that I will just wait then until I can get some RMI-25.
where can I get Evans coolant!
BLACK6PACK-> do your guys in south florida all use distilled water and no anti-freeze?
Evans Coolant
Check out the link to the Evans website as given above for lots of info.
A simple radiator flush is all the prep we do...we use the Atlas Backflush machine.
HTH :)
who here had the EVANS NPG+ installed. Besides a good flush what else is needed? I looked at the site and they talked about removing the thermistat and changing a pulley!!!! Besides that all the old water had to be flushed out completely.
Evans Coolant
The Atlas Backflush machine reverse-flows & cleans your entire coolant system.
Then, to empty out the residual water from block,
we use a 6.5 hp electric blower (230 mph) attached to the upper rad hose, pushing everything out the lower water pump hose.
If you wish to lower your rad cap pressure, or put in a new thermostat, that's your option, & there's no better time.
HTH :)
BTW, distilled water by itself is extremely corrosive, and it'll kill your water pump in one trip around the block...
