Which Water for Cooling System?
Use DI H2O
Yes DI may attract some minerals from the coolant passages, but very limited as it reaches equilibrium quickly. May be somewhat beneficial if there is some accumulation. You might consider a DI flush & dump, then fill. I run DI, RMI & aluminum safe antifreeze. My engine short block is the least clean component in the system.
