Oct 2, 2002 #1 T the wrath Active Member Joined Sep 29, 2002 Messages 1,340 when i start my car my fan stays on and it is on high it wont shut off until i turn the car off
Oct 2, 2002 #2 S sam87 old but still runnin Joined May 25, 2001 Messages 174 High speed fan relay is bad or is being closed/grounded by coolant fan temp switch or by a/c high pressure switch. Disconnect 1 at a time, starting with the switches, to find the bad 1. Fan will stop with the bad 1 disconnected.
Oct 2, 2002 #3 B Black Car Active Member Joined May 25, 2001 Messages 1,032 Another possibility is the chip. Some chips are programed to turn the fan on when you turn the key on. Gary
