SignUp Now!No real background in heat transfer, huh, Nailhead? The problem with pure water is that it boils too easily. When it boils, the resulting steam is a MISERABLE coolant. You will get steam blanketing, a resultant hot spot, and big old bad detonation! The bulk temp, as read by the temp sensors, may be much lower than you would expect to get boiling, but the whole engine is NOT at that temp, it is the "mixed" temperature of all the coolant that has been anywhere in the engine. So you make a compromise (heat transfer has lots of those) and use a coolant, like NPG, maybe, which isn't as good in some ways as pure water, but is better in other ways, like the boiling temp.also the myth with antifreeze that it helps is BS
