Every cars different, I run 5 psi in the passenger side and zero in the drivers. I have Mickey Thompson drag radials, 15psi tire pressure. My care pulls 1.59 sixty foots. 6262 precision turbo, 6psi boost off the line. Hope this helps.
Thanks Phil, that is lower psi setting than I expected. Obviously works for you looking at your 60'.
I also have MT D/Rs and was expecting to use 20lbs.
Interesting, any other views?
