Correct lugnut for weld draglite w/ stock studs
PaulRV6
Are these the correct lugnuts to be used with the stock axle studs? 601-1412 12mm x 1.5" long shank, closed end
Is this the best alternative to changing out the axle studs to longer ones? I want to be able to go back to the stock wheels at times.
Thanks allot.
paul
Those will work,But if you run slicks Rules say you need longer studs.Threads need to protrud 3 threads past end of lug nut.You can change to longer studs and just use an open end acorn lug nuts for the stocker wheels.
Would I be okay using drag radials? I will probably never run an NHRA track though, our local track is only IHRA.
Thanks, paul
It's not just nhra it's ihra also.Just depends on how well your track does tech.If your car hooks hard you may want to change them to longer studs just for safety.Seen many a quarter panel crunched because of wheel studs breaking.
