V6UnderPressure
The Artist FKA Scott4DMny
- May 27, 2001
Here I have for sale two similar packages. These are custom built Currie 12-bolt rear ends with trutrac posi. Both are exactly the same with one exception in that one is 3.73 gears and the other is 3.42. Powder coated satin black.
1. Total width is 1.5 inches larger than stock, in other words 3/4 inches longer on each side than the standard gbody width.
2. The housing ends rotated towards the back 20 degrees from your standard location.
Both of these things were done to provide additional clearance for the brake calipers.
3. brake line tabs welded directly under the spring perch where each flex hose would connect to the hard lines.
4. Poly upper bushings.
5. Large Ford Torino Housing ends.
Also included is the Kore3 rear C5 installation kit which incorporates the C5 emergency brake etc. just need C5 calipers and rotors.
Lastly the package includes a new set of Weld RTS 17x7 fronts and 17x8 rear with correct backspace. Front tires are 225/45 and rear tires are 255/45. One set polished, one set polished with black face.
First buyer can choose which rear end and wheels.
Price is $3900 obo for each package.
Will consider trade plus cash if you have an 8.5 rear end but I only need one. I’d actually even prefer just a core. But a full rear would be fine.
I will not ship so local pickup only in the Chicago area. Willing to meet within reasonable distance. Will be heading to Iowa within the next two weeks as well.
