V6UnderPressure
The Artist FKA Scott4DMny
- May 27, 2001
Selling a brand new custom Currie 12 bolt rear end
This is a custom built Currie 12-bolt rear end with Ford 9 inch large Torino ends. Inside built with trutrac posi & bolt in 33 spline axles. 3.42 gears and 1350 yoke. Powder coated satin black.
1. Total width is 1.5 inches larger than stock, in other words 3/4 inches longer on each side than the standard gbody 10 bolt width.
2. The housing ends rotated towards the back 20 degrees from your standard location.
Both of these things were done to provide additional clearance for brake calipers if you went with discs.
3. brake line tabs welded directly under the spring perch where each flex hose would connect to the hard lines.
4. Poly upper bushings.
5. Large Ford Torino Housing ends.
This rear fits like a glove!
You can decide what brakes you want to run. There are many packages available that you can find for the Torino ends.
I will not ship so local pickup only in the Chicago area. Willing to meet within reasonable distance.
$2600 for the rear. Costs over $3500.
