Newer PS pump, Chips, New Line Lock, New coil pack, Magnacore Wires, LT1 MAF, New Areomotive, ETC
jdpolzin
Magnacore Plug Wires (red) $50
PS Pump with RJC pulley (pump has 6000 miles on it) $150
Extender Chip (50# injectors, Alky, Anti-Theft) $40
New Duralast Coil Pack $50
New Moroso Line Lock Kit $85
Newer Dual Airbag Kit (w/spacers, lines, and heat shields) $100
Newer HRParts upper Control Arms (mounted but never ran) $200
Newer HRParts Lower Control Amrs (mounted but never ran on) $200
Stock Exhaust Elbow with Dump (used but not long, nice condition) $50
Reds Chip (not sure on the tune, I think it was 36# injectors) $20
New AeroMotive Stealth 340 Fuel Pump with New Racetronix Fuel Hanger Wiring Kit $200
New Racetronix Hotwire Kit $50
Weld Draglites (15x8 with a 5.5BS, has some minor curb rash but no bends) $225
Kenne Bell Air Dam (modified to flow air to stock location IC better, comes with the filter eblow) $500
Stock OE chip $25
Original Radio (needs work, tape player stays on) $25
Core Support Front Braces (original ones that cross each other in front of radiator) $25 pair
Magazines, Books, Literature, etc (wont separate) $250 for the lot
WBO2 Extension Harness $20
Ridler Torque Thrust wheels (17x9.5 with 255/50/17, 17x8 with 235/45/17, these are basically new) $950 set
New Energy Upper Control Arm Bushings (Rear, for upper ears on the rear end housing) $25
Rear Spring Isolaters (pair, used) $10
New SoffSeal Passenger Door Weatherstripping (lower, just one side) $20
Reds Fuel Enhancer (Old School! Not sure if it works, more of a conversational piece IMO) $20
Coil Pack and Ignition Module (known good) $140
Bumperettes (rear pair, black, one has a chunk of the rub strip missing but otherwise good condition) $30 pair
Rear Trunk Fillers (Between trunk lid, and rear Window, one is for hardtop, one is for vynal) $30 each
Alternator Core (Hot air) $10
New Stock Replacement Starter $40
Driveshaft (stock yoke, stock U-joints, 1" shorter than stock) $50
86-87 Engine Harnesses (two of them, need repairs, missing ends, etc) $100 for both
Brake Line (one, master cylinder to valve) $10
Stock Heads (pair) $50
Dash Surround (Blue, pad that goes around gauge cluster and column, nice condition) $40
Grey Steering Wheel (not perfect, but not too bad, driver condtion) $75
Hot Air Turbo ( Spins freely, Ive never ran it though) $100
Interested in that Kenny bell air dam System if price is flexible
Post some pic ' So I can decided .
You mean for rear?
You mean for rear?
Yes these are rears. I don't have pics of the lowers but can grab some for you.
Hey Rick, it's looking like there are two other guys in line waiting on pics from me. I'll keep ya posted.
Here are a couple pics of the two harnesses. Neither are complete. I really can't tell ya much about them aside from they need work or are for parts. These are still packed up in the box they were in when I bought them, so I haven't investigated much!
If the coil pack and module are original factory AC Delco units I'd like to get a pic of it.
I am not 100% on whether it's an original unit or not. It doesnt have the stickers on it. This is one I've always kept as a spare to test with. I do know that it's 100% positively known good.
