Magnacore Plug Wires (red) $50
PS Pump with RJC pulley (pump has 6000 miles on it) $150
Extender Chip (50# injectors, Alky, Anti-Theft) $40
New Duralast Coil Pack $50
New Moroso Line Lock Kit $85
Newer Dual Airbag Kit (w/spacers, lines, and heat shields) $100
Newer HRParts upper Control Arms (mounted but never ran) $200
Newer HRParts Lower Control Amrs (mounted but never ran on) $200
Stock Exhaust Elbow with Dump (used but not long, nice condition) $50
Reds Chip (not sure on the tune, I think it was 36# injectors) $20
New AeroMotive Stealth 340 Fuel Pump with New Racetronix Fuel Hanger Wiring Kit $200
New Racetronix Hotwire Kit $50
Weld Draglites (15x8 with a 5.5BS, has some minor curb rash but no bends) $225
Kenne Bell Air Dam (modified to flow air to stock location IC better, comes with the filter eblow)  $500
Stock OE chip $25
Original Radio (needs work, tape player stays on) $25
Core Support Front Braces (original ones that cross each other in front of radiator) $25 pair
Magazines, Books, Literature, etc (wont separate) $250 for the lot
WBO2 Extension Harness $20
Ridler Torque Thrust wheels (17x9.5 with 255/50/17, 17x8 with 235/45/17, these are basically new) $950 set
New Energy Upper Control Arm Bushings (Rear, for upper ears on the rear end housing)  $25
Rear Spring Isolaters (pair, used) $10
New SoffSeal Passenger Door Weatherstripping (lower, just one side) $20
Reds Fuel Enhancer (Old School!  Not sure if it works, more of a conversational piece IMO)  $20
Coil Pack and Ignition Module (known good) $140
Bumperettes (rear pair, black, one has a chunk of the rub strip missing but otherwise good condition) $30 pair
Rear Trunk Fillers (Between trunk lid, and rear Window, one is for hardtop, one is for vynal) $30 each
Alternator Core (Hot air) $10
New Stock Replacement Starter $40
Driveshaft (stock yoke, stock U-joints, 1" shorter than stock) $50
86-87 Engine Harnesses (two of them, need repairs, missing ends, etc) $100 for both
Brake Line (one, master cylinder to valve) $10
Stock Heads (pair) $50
Dash Surround (Blue, pad that goes around gauge cluster and column, nice condition) $40
Grey Steering Wheel (not perfect, but not too bad, driver condtion) $75
Hot Air Turbo ( Spins freely, Ive never ran it though) $100
