Correct spacer thickness to use GTA "rears" ?
toofastforyou
2FAST4U
What's the correct thickness of the needed spacer to use GTA "rears" with 245-50-16's on the front?...A friend of mine says 3/4"...Is he right?...If yes, that would imply that I'll have to use some longer studs...:frown: I currently have some 1/4", 1/2" spacers and also a set of 1.25" adapters...Any chance these will do, or will I still have to get some other ones? :confused:
Thanks,
Claude. :smile:
Trial and error I guess. Bolt them up with the .5" spacers and check for rubbing. If not, throw on the adapters.
The Rears in front with 1.25" adapters will work fine. They will probably work ok with .5" spacers, too, but may rub the frame when parking.
Thanks everyone for your replies. I think that I'll try my 1.25" adapters (I already have them...) and see if there's any rubbing...
thanks,
Claude. :)
