The reason I ask this is because ever since I connected my Alky kit (Razor's minus the controller) I have had an issue where I can run it once and anytime after that the car will bog and even misfire at WOT, especially in the low end. I attributed this to bad tuning and decided to not play with alky until I get a controller.
Well, the other day I put in my street chip and took the car out for a drive. I got on it and it ran fine. After that the car would pop, sputter, backfire if I hit it from low RPM's in 1st gear. Keep in mind that at this point the Alky system has no power going to it and I'm running my street chip with 15psi.
If I get into it from a 45+ mph roll or ease into it from a slower roll the car runs fine. No knock, o2's are fine, etc.
Before you all ask, yes, the nozzle is up higher than the resovoir. Maybe something else is horribly wrong, but could this be because alky is dribbling into the intake, or maybe the IC even though the system is off? What could be wrong?
Thanks,
Mike
Thanks,
Mike
