Originally posted by BJM
I have been looking at the GNTTYPE spreadsheet for a while.
The WOT spark tables cover the ranges 400, 800, 1200, 1600, and 2000 RPM for LV8 up to 176. Are the regular tables used for the speeds above 2000 RPM?
There are 6 MAF tables shown with something called PP2counts as indices as well as a scalar. I thought there would be a MAF table for every BLM cell.
The WOT spark table is for spooling, and to keep the car out of detonation. Thou on the TTA they have the enable set to 99.6%.
Personally, I just always set it at 99.6.
yes, at over ~2K you change to the main timing table.
The way I use/understand the MAF tables and scalers, is:
Just to pick some numbers and give some meaning to things.
Say table 3 has a scaler of 20, and the 10th entry in that table is 200. To convert that to gm/sec., you multiply 20x200, and divide by 255. So you'd have 20x200, and that's 4,000 divide that by 255 and you have 15.6. So at that table value, ie MAF frequency the ecm thinks the engine is using 15.6 gm/sec of air.
Now as you tune the car if at 15 grams /sec as indicated by the scanner if your lean, you would want to find that 15 in your tables, and then slightly increase the entry value to have the ecm think it's actually using more air at that frequency. And you'll note as you edit things, they begin to shift, and it can get kinda confusing to get it.
The thing with having the MAF tables correct, is so that as you go into PE mode, and the ecm calulates the new AFR, it's basing that calulation on the MAF tables. So yes, you want them as close as can get em. A WB is REALLY helpful for doing them.
When I'm roughing out the MAF tables on a hot rod, I set the PE TPS enables higher then stock so as to get as much of the MAF tables as correct as I can. But, I'm extremely careful about not building much if any boost when doing that, and then immediately set them back down. Headgaskets won't last long at 14.7 AFR in boost.
You'd do well to just forget about what cell your in. Look at the gm/sec to see what the ecm needs.
But, in part tuning is an art form so you'll probably see other ideas about what works for others.
