Could someone look at a Direct Scan file for me?
TRBON8R
I recorded a run this weekend with Direct Scan and I'm getting some knock as high as 6.5 degrees shortly before the 1-2 shift and for a couple frames after. Then knock goes down to between 0-1 degree or so and then stays constant.
I was hoping I might convince one of the gurus out there to take a look at this file and see what you think.
Quickwrench,
I tried sending the file to you but your email address bounced. Maybe it was a problem with the attachment......... :(
I've got a few files I would like looked at. They aren't pretty.
Bob,
I would like you to look at them also. I've been speaking with Steve Y and he says I need to get a few things from you.
Brad
Turbon8r, I sent a response to the email you sent to me, but it bounced. I will try sending again tonight.
Black6pack, go ahead and email me with your files too. Or, give me a call 727-856-2733 or 813-505-2580 (after 3:20 PM) Thursday to talk about what you need.
-Bob
Thanks Sean, I emailed you a response to some of your questions.
Bob, sorry the email bounced I can't quite figure what the deal is there :confused: If you could try and resend I'd appreciate it.
Sully, I just sent the file off to you. Thanks!! :)
