I have the Grey box fast system, And I have a couple of questions I was hoping you guys could help me with.
When I'm trying to start it the car it wont fire by cranking it alone, if I work the throttle it will start after I release the throttle and stop cranking, it will start to run and if I work the throttle for a second it will start and idel just fine around 1000 rpm (the tack says 1000 - 1100 but fast reads 650 -750 ). It revs with out any problem. any thoughts on what table I need to adjust.
And second is the fuel pump, after the car warms up 150+ the fuel pump will not re-prime, it dose not kick on when I'm cranking the car nor dose it prime when I turn the key forward, it only hapenens when it warm if I let it sit for 10 minutes it primes right away with a problem. I do not have a check valve inline, the pump is a BG king sumo. Any ideas
Oh I almost forgot the car is a 1996 mustang with a 331 and a t70.
Any light you guys could shed on this would be great, and Norbs thanks for all your help in the past with questions
