thunderace31
Banned
- Sep 2, 2002
Just checking if I should sell them or use them some say I will be cool other say I am going to need 60's
SignUp Now!No problem with the meth especially on a stock headed engine. My friends car went 126+mph at 26psi with 50's and a dual nozzle meth set up while weighing 3700lbs.thunderace31 said:Heads are stock but I do have 206/206 cam
Was planing to run 20-24lbs of boost.![]()
What do you think??
Philv6 said:Mileage with 60's should not suffer if the tune is right. That is as long as you keep your foot out of it. I have 65's and the last trip to Bowling Green, KY. I got 28mpg. The city mpg is not as nice since I like to make sure there is never any carbon build up in the motor. ( WOT blasts)![]()
matt87 said:60's with a turbo tweek chip has been the best smoothest running combo i have ever used. i've had 50's 72's 36's 42.5's and still like the 60's best.
He wont be at 100% with the methanol. Should be able to get 124-126mph out of it before he needs more injector with the meth.TURBOV6 said:I think the 50's are min or not reccomended for the 66. If you do run the 50's you won't be able to run high boost.
Is the chip for the 50's burned to run the 66?
You will probaly max out those injectors (close to 100% duty cycle). Would be safe to just sell it and go with the 60lbs injectors.
