Craig,
my FAST Sefi has a Code 132 in the dashboard, not sure what that is, but car is not starting, I also noticed that the cam sync stays at 0 while cranking, I never noticed the cam sync before, should it be giving some sort of RPM number or should it always stay at 0.
the injectors are firing and there is ignition at all plugs.
This is working fine before, I have a feeling my distributor went on my.
My distributor has two sensors which I use the trigger and the cam sync.
Thanks Craig, appreciate some help this is killing me as I wanted to hit the dyno yesterday but couldn;t
Greg
Greg
