lilthumper
In front of your regal
- Jun 20, 2001
After giving up on any electrical or FAST bugs, I went ahead and tore down lilthumper to check my valve adjustments, look for any broken springs, etc.. I did pull the plugs to find that everyone of them were more black than my diesel's tailpipe. OK...I know my tune is not the cause of this because the actual A-F is not that rich, it reads 10.5-12.5 depending on the RPM. I decided to OHM my 1 month old Taylor 9mm wires. Here is what I got. 6 wires were in the range of 600 to 900 ohms depending on the length, I did get a reading of 3500 to 5500 ohms on the remaining 2 wires. I performed this test 3 times and always got consistent readings on the 6 wires, but kept getting zero reading or 3500-5500 on the remaining 2. My question is, could 2 bad wires cause this big problem? Should I go buy another set and put the stuff back together or just continue to tear down the motor checking for something else.
