yea i went and checked the the worksheet they just honed the bore not bushed, so the behives pac bbc wil work on the gn1s whats the lode on those springs the person selling me the cam said that he used the comp 941-12 but he had cast head dont know if that spring will fit on the gn1s if not then i would have to get the bbc behive pac .like cme2fly stated .so i would have to set the valve lash at .006-.007 at tdc.like norbs stated .man guys thanks for your time really needed your experience hear .thanks again.[/QUOT
I want to say that I had around 220 at the seat at a 1.800 install height with the PAC beehive. I don't use comp springs but, I'm sure comp has a decent bbc spring available. With a 206 cam I wouldn't be to worried about exposing the lifter oil galley due to the fact your cam is probably around .490-.500 lift. As Norbs stated I would stay below .540 lift, unless your planning on bushing the lifter bores.
