I'm trying to track down the slight wable my crank pulley has in it. It appears as though the hub/pulley has a slight wabble. The balancer does not look to be wabbling at all. This just started after I removed the balancer last weekend for a timing chain install. After removing the hub today it seems to have to holes drilled in one side as though it is balanced. Is there any special reference this should go to on the balancer? The GM service manual does not say anything about it. I'm about 90% sure this is where the wabble is coming from. Also which bolt got for the hub to balancer the longer ones or the shorter ones (the pulley has the same number is why I as)?
TIA!
TIA!
