May 15, 2003 #1 8 86gn Glenn is slow!!!!!!!!!!!! Joined May 24, 2001 Messages 553 What are the advantages and disadvantages of using a 3.40(buick motorsports)steel crank in a stage 1 motor? John
May 15, 2003 #2 Q qwknuf6 jr 100% street car Joined Mar 6, 2002 Messages 358 Disadvantages are few, maybe the cost. Advantages are in the stregth and that alone is worth the extra cost . Mark
May 16, 2003 #3 8 86gn Glenn is slow!!!!!!!!!!!! Joined May 24, 2001 Messages 553 just wondering on the stroke with that crank vs the other larger stroke cranks out there.
May 17, 2003 #4 D dow j New Member Joined Jan 17, 2003 Messages 65 Shorter stroke advantage?Maybe rev quicker.Disadvantage to a larger stroke crank,would be less cubes.Jim
May 19, 2003 #5 R RegalX2 New Member Joined May 26, 2001 Messages 89 Advantage : if you've got a nice steel crank, use it, maybe less bearing wear with 3.400 vs. the others. Jim
