crank sensor wiring
Twin70BB
Trying to get my stage motor running.I have 3 wires coming out of the crank sensor.I have a red,green,black.What is what.If anyone can help.
Tony
Tony
Per the wiring diagram over at gnttype..... the gray wire with the red stripe.... is 12V.... the black wire is ground..... and the dark green wire goes to the smarts inside the ignition module....
HTH
Red: Positive 12 V
Green: Signal
Black: Ground
That's the wiring on the 85 style sensor. The 86 sensor has an integrated connector on it, and GM screwed up with the color code, so it turns out that the Green wire on the 86-87 harness is actually +12V and the gray/red is the signal wire - only for the Crank Sensor. The Cam Sensor gray/red wire is +12V.
Good old GM with too many chefs, back in the 80's.
