Seems to me like my GN has excessive crankcase pressure. Even my kn breather filters are getting super dirty from the inside of oil. They went from red to a very dark brick red, on the verge of brown.
Secondly, after taking utmost care in replacing the oil pan gasket this most recent time, it still leaks. The valve covers do not leak. Oil pressure is over 40psi at hot idle. Seems to me like the motor was rebuilt. In that respect, if and when I open up the part of the engine where the stock oil filter goes to see the gears, what should look like? Anything I can do there to lower the pressure a bit?
If I can't fix the pressure that way, can I tap the oil pan put a -4an host an connect it to the valve cover on the drivers side to relieve the pressure? Thinking that will cause any pressure to route to the valve cover which has a breather that is not clogged. Also on both sides the valve cover breather grommets are opened up enough.
