Cranks no start no inj pulse no spark
Tferst
I am new to turbo Buicks I found the no start tree followed it and keeps coming up with crank sensor or connection I replaced the original. Style to the. Newer style gapped to .025 and no luck I followed it again and still coming up with same thing I checked cam sensor alignment again at .25 after window points to drivers headlight she spins when cranking im lost please help me out don’t want to throw new parts at it even thought couldn’t hurt having extra stuff laying around
Not sure where you got that info.
More info needed.
Did it run prior to?
Did you check all the fuses, connections, etc?
More info needed.
It ran
More info needed.
it did run before I did exhaust manifold gaskets and water pump I have checked fuses and connections I took off multiple times
Check for 12V power at the ignition module, and check out this little video.
