mattsTurboT
- Jan 5, 2004
hey guys im getting aheadache with this problem... let me explain
turn car on
blms good till rpms start to even out in park then they climb to 148-160.
throw it in drive and give it some gas and blms drop from 140-160 to around 110-120..
then cruising on the highway if i let of the gas blms will sometimes go as low as 96-110. but as i start to ease back into the gas it starts to climb up to the mid 120s.
then when am braking and just about stop blms shoot up to 145-160..
ok, many new vaccum lines. all that were bad were replaced.
new pcv a month ago..
just replaced driver side header today which did not help ONE bit!!
i know valve cover gaskets and intake valley pan is leaking. could this be a cause.
also i can smell the car is running rich.
i replaced egr solenoid because one of the nipple was broken off and was duct taped for a while by the previuos owner.(ive only owned for a month)
the egr is a used one but was in good shape.. dont know about internally though.
injectors off a 50k mile gn were put on just before sold to me. along with o2 sensor.fuel pressure has been played with to try to fix blms but didnt do a thing.
PLEASE REPOND.. i cant afford to have the head gaskets blow or something like that this is my daily driver.
1987 charcoal turbo t. 153,000 miles. afpr,fuel psi gauge,scanmaster,casper fan control,walbro 340 with hotwire,RA 93 street chip.peglegger with 275/60/15 bfg radial t/a's
turn car on
