I posted this on the Scan Tool board but since I hardly read those posts, I'm putting it here also.
I'm getting crazy knock readings on my scanmaster and I want to make sure it isn't something someone else has run across before I tear into looking for it.
I can be cruising along at a nice steady speed 25-30 or 65-70 for example and the scanmaster will show knock that jumps all over from 0 to .5 to 20 to 8 to 11 to 15, just all over and the O2's are in the 700-850 range. If I push the recall button there isn't anything there and I don't hear anything knocking.
How in the workd can you get knock just cruising along at a steady 30 MPH?
I've got a Max Effort 16 pos and 55's if that helps. Right now it's all set on default settings.
Any ideas?
Thanks - Terry
Any ideas?
Thanks - Terry
