Crossover Pipe
84GNTTYPE
Senior Member
What kind of gaskets, if any, are on the crossover pipe(where it connects to the headers). I have had an exhaust leak for some time now and I finally have the time to fix it and I'm pretty sure it's coming from the crossover. Any help would be appreciated!!
Thanks!
no gaskets on them , i would drop it and put some copper rtv on it were they met the headers and let it sit over night .
i doubt its leaking from the crossover, since theres no gaskets involved, only a bell-like fit. If anything, the bolts are loose. What might be leaking is a header gasket. The passenger side head is poorly designed when it comes to the exhaust ports. the wall on cylinder six is very thin and gaskets are very prone to blowing at that spot (at least in my case). If this IS the case...i suggest either buying copper gaskets, which can run a bit pricey, or use no gasket at all, and just seal it up tight. I know some people who use the copper RTV by itself for the header gaskets, but i've never had much luck with it. hope this helps.
If you determine it to be the crossover pipe itself, I have a low mileage original in the Parts section for $35 plus shipping.
