If you are running a Crowler crank and a Pro Gear timing chain set, you might want to check the clearance of the chain (on the crank sprocket) with the number one journal. The links and pins on the chain will touch the journal. The fix is to machine the journal and place a radius on the edge.
Jeff
Jeff
