not entirely sure about every part needed, but just to get you started i know the cruise diaphram assembly and bracket its mounted in is same as 86/87, not sure what other cars are same. i know the cable itself is differant than the 86/87, and most likely its unique to hot airs only. the controller than mounts under the dash is the same on all 84/87 trs, those rarely fail (i think), so shouldn't be too hard to come by. the turn signal stalk controller is obviously easy to come by. hopefully your wiring harness under the dash and engine and instrument cluster (for the cruise lamp) has all the proper connectors just hanging there, otherwise your in for a bit of wiring and splicing. not sure what else is needed. the only thing i see might be tough to find is the proper cable. i might have an extra, not sure
