cruise control wiring
Henry Albert
Would someone be able to post a wiring diagram for an 84 column with cruise. I am adding an aftermarket cruise system on my 57 Chev but want to use the GM control lever. Thanks, Henry.
Click on thumbnails for full size...
RemoveBeforeFlight
Thank you. I did not realize that the cruise wiring was separate from the column wiring which left me confused. I traced a black covered set of wires and finally found the flat blade connecter. Now to wire the Digital Dokota system into it. You know it is funny that I rewired the 57 completely but forget some of the things I had done, takes a while for the brain to function some times( and that is my story and sticking to it.)
