III'S 87 GN
- May 19, 2002
CRUZ Performance NEW product throttle body vacuum block delete kit
Remove that 30+ year old plastic factory throttle body vacuum block that is ugly with all
of its hard lines and leaking rubber lines going to it.
This kit is easy to install and comes with the majority of the pieces needed to do the conversion (example may need 1/8 inch to 1/4 inch hose adapters)
CRUZ Performance NEW product throttle body vacuum block delete kit includes
1/2 inch plenum spacer (fits under stock hood)
2 new plenum gaskets
stainless allen head mounting bolts for plenum
throttle body delete plate
CRUZ Performance vacuum block (5 x 1/8inch ports, 2 x -6 oring ports)
7 x 1/8 push lock fittings
2 x -6 oring fittings (specify female 1/8 inch hole or -4 male AN)
20 feet heavy duty black nylon push lock hose
$249 complete kit shipped to US
ADD $25 for swap to 1 inch plenum spacer for performance and addition of inlet temp sensor
(for stock or Champion intake)
CRUZ Performance plenum spacer, vacuum block and throttle body delete plate
made in Florida, USA.
Please call ,text or email
813-399-0409
don@cruzperformance.com
www.cruzperformance.com
https://www.facebook.com/CruzPerformanceTampa/
813-399-0409
