CRUZ Performance TurboBuick Holley kit
New Custom Harness Video. Watch Here!
https://youtu.be/RTQtV70O0Z8?si=1_BDz9zogRCuroDo
On the road to 1,500 harnesses!
Off the table and just made!
CRUZ Performance
the “ORIGINATOR”
Turbo Buick Holley Harnesses
PROVEN Since 2016
Made in the USA
QUALITY Without Compromise
1 Stop SHOP For Holley and all Your Turbo Buick Needs
CRUZ Performance Supplies Every Piece Needed to make Your Install Seamless!
CRUZ Performance Turbo Buick Harness made to Custom Specifications or Standard Versions With all Necessary Holley REQUIREMENTS of
shielded cable on Crucial Sensors like
Cam
Crank
and Wide Band
plus Holley REQUIRED 10ga Power and Ground Wire direct to the Battery
All Connectors laser Engraved for easy Identification and connection
Preferred choice
6 Individual Smart Coils for HP & Dominator
6 Individual LS Coils for TerminatorX
Or can use
Stock Buick Coil Pack and Module
Or
Truck Coil
CRUZ Turbo Buick Holley Self Tuning kits include Everything Needed for Startup
No chasing parts needed for install!
Holley ECU of Choice
CRUZ Custom Plug & Play Harness
6 Smart Coils
CRUZ Coil Hotwire Harness
Holley Wide Band
MSD Spark Plug Wires
CRUZ Coil Mounts
Startup Tune loaded with latest Holley Firmware Flash
Tech Support
TerminatorX kit
COMPLETE
TerminatorX MAX kit
COMPLETE
HP kit
COMPLETE
DOMINATOR Kit
COMPLETE
Options include
Holley 12.3 Dash
Turbo Buick CRUZ Custom Mount
Bezel
CRUZ plug & play Dash Connector for 12.3 or 6.8 Holley Dash
Holley 6.8 Dash
CRUZ Mount
CRUZ High End Injector Harness with Sealed Loom and 90* Rubber boot ends
For Stock Style Injectors or any Other Style needed
Holley Boost Controller
FlexFuel Sensor
And MORE
CRUZ Performance is a Elite/PLATINUM Holley Dealer for Turbo Buicks and All other Models dedicated to Supplying Holley Specific Requirements and Specifications that have PROVEN to Work
Thank you
813-399-0409
Don@cruzperformance.com
CruzPerformance.com
