cruze ls iac
william B.
I purchased the cruze ls iac conversion,im running a fast xfi 2.0 system, can anyone tell me if this is a plug and play ,or do i have to go into the program an change set points ? thanks
You’ll have to just try it out. You’ll probably need to change something especially if your using closed loop idle control.
Why change from the stock one?
Bit newer technology & allegedly faster than the old IAC.
I have one with stock(modded) ECM. Was plug & play with the Cruz wire whip.
Honestly I can’t really tell any difference from the old one.
Quality of some stock replacements seems to be getting sketchy. Autozone stuff maybe not so great! I can definitely see swapping to this new IAC if the stock replacements are being a problem.
Another reason is not needing the angle adapter if you are running a 4" inlet pipe.
i do have the angle adapter installed now, idle qualitly is good,around 25 t0 50 rpm variation from my set point of 950 rpm,aic counts on average 15,have tr6 with cop,has a clean idle,but thought this aic mod could make it better.
