curious about power gains from liquids??
HGturboT
HomeGrownPerformanceLV
I personally don't know about these liquids, but was wondering just for say if I were to put a alcohol, propane, etc. system on a bone stock buick (boost, fuel pump, injectors, fpr, etc.) would it work/make a difference or just could'nt happen. Could the stock fuel delivery handle it no problem or not?. What I'm getting at is would I have upgrade my fuel system like if I was adding alot of boost or is it in the fuel itself?
you need AT A MINIMUM, a 340 walbro pump and hotwire kit before you even think of touching your wastegate. after that sure the alky will provide gains but only at higher boost levels.
Do the fuel pump and hotwire kit then add propain. It is nothing more than a better fuel. You will need to turn the boost up to lean it out to where it was originally. HTH
