Ok guys no more well it works with my turbo & well it kinked on mine. The gasket is leaking because I'm fighting the drain line etc.. I heard them all
Here you go. On sale till the end of the month.
GBodyParts.com Online
Aluminum Flange that can be installed on your turbo with gasket. No more fighting the hose pressure to get it lined up.
Install (1) end of a blue 1/2" NPT thread into your block with teflon tape. No hose to get in the way. The 12" black hose is oversized in length.
Simply push on the block thread. Bend to desired length then cut. Now install your blue AN fitting to your turbo flange. Once again no hose in the way fighting you. Push your hose on to your turbo fitting and you are done!
Almost too easy & very clean looking.
We sold 15 in the last 2 weeks & nothing but compliments not complaints. Man that was a nice change :biggrin:
