I have a factory heat shield thats been cut for a aftermarket downpipe. I have no idea for what pipe.
$25 shipped to the lower 48.
lower intercooler fiberglass scoop for the stock plastic shroud.
fit is perfect, but keep in mind the holes where drilled for my shroud. the holes also line up perfectly with a couple other shrouds I matched it with, but I have no idea if the holes where jigged and drilled on assembly, or if they where eyeballed. You may have to re-drill if they don't match your shroud exactly.
it is in perfect shape, no cracks. I never painted it.
$30 shipped to the lower 48
