ttypewhite
- Oct 1, 2001
I have the classic FAST bank to bank in my car. I started the car and it feels like it is running on 4 cylinders. I pulled the injector harness off those 2 cylinders and it makes a very suttle change. So i pulled off the spark plug wires on that cylinder and stuffed a plug in the end and keyed it over. The spark is very weak. I tried all the other spark plug wires and they are very strong. So I tried relocating the spark plug wires to see if its a dead wire. They work good in another cylinder so that elimunates the wires. I pulled the cap off of the distributor and changed the rotor and cap. Nothing, still running on 4 cylinders. I pulled out the distributor and put in another one, same thing. I also changed my coil with another one. Still no dice. Where else can I look? Why is cylinder #3 and #5 weak and the rest strong?
