I was thinking of putting 3 1/2 inch mids in the dash, along with 5 1/4 mids in the lower doors with 1 inch Tweeters in the top of the door near the power window switch, if they are all 8 ohms and wired in parallel so they would act as fornt left and rights then have 6X9 2 ways in the back dash and 2 12 inch subs in the trunk, would it sound good? Wonder if I have enough highs coming from just one set of Tweeters in the doors to go along with the 2 sets of mids, 5 1/4 and 3 1/2.
I would be running it all from a 5 channel amp, 75 watts to each speaker.
Effectively the 8 ohm speakers would look like 4 ohms to the amp and I would still have front to rear fader control, only the mids and tweeters would act as one set of fronts to the rear 6X9's. Any advice is appreciated.
