The above post is close.
Disconnect the battery first...
To remove the dash, first open the hood and take the center bolt out of the bulkhead connector on the drivers side (1/4")
Under the dash you will need to remove the 2 screws that hold the inner part of the bulkhead connector to the firewall (2-7mm screws)
Lower the steering column, or remove it completely as this will facilitate removal of the dash. with the column out of the way you should beable to depress the lock to remove the speedo cable from the back of the dash.
Disconnect parking brake release cable from parking brake assembly.Unbolt the 3 10mm bolts under the dash. 1 each in the outer corners and 1 to the right side of the radio/heater control area.
Remove the radio, and unbolt the heater controls from the dash shell, allow the heater control to fall to where the radio was. When you pull the dash out, that will stay in the car. disconnect the wiring from the AC controls to the rest of the dash wiring.
Disconnect the 3 connectors under the right side of the dash.
Remove the top speaker grill (either 7mm or 1/4") cover then remove the 4 7mm screws that hold the top of the dash to the firewall.
At this point the dash *should* be loose. it may be easier to have a helper take the dash out of the car.
There may be more connectors I do not recall off hand, but thats pretty close. Good luck... a first timer may take 2 hours OR more to get out... Installation is reverse of removal.
