datsun update
87rdgn
I made two passes.The first pass was an 11.55 at 112mph with a 1.65 sixty foot time.The second was an 11.70.I was running 15lbs of boost.The motor is 030 over with a 206 .496 lift roller cam and a stock turbo.
Thanks.I need to get the two step to work on the msd box so I can use the trans brake.If I rev the engine to 4000rpm on the trans brake , the boost will go to 15 lbs.It should make for an interesting launch.It only weighs about 2600 lbs.
I saw this truck run at QCMP and you should have seen the heads snap when he pulled up to the burnout box and did a burnout.:biggrin:
I just bought a TE60 precision brand turbo monday from gbody parts. I have it on but need to figure out how to tune the fast efi because it is correcting the 02 readings at 15 to 20 psi as much as 24%.I saw Kevin run his 5.0 mustang QCRW.I was very impressed with the times his car turned.
