I noticed that I was getting some bad popping when I would let off the gas
and coast. I took a good amount out of the VE table in the areas where
necessary in the 1000-3500 rpm range down in the low kPa area. This
seemed to help immensely but I still get some various popping and I think
it's due to the next point I will bring up.
If I am cruising and watching my corrections, they are all under 5% either +/-.
What's strange is that as soon as I let off the throttle the WBO2 registers
15.9:1 AFR and the corrections swing to +24.2% and that's when I get the
popping. My question is what causes the AFR to go to the high 15's there
and what causes the big correction. I can't see how the car could possibly
be going lean at this point as the WB is indicating. Is this something that needs to be
addressed in the deceleration enleanment table?
